Need help with my settings for o/c
TooRude
hey guys I must be doing something wrong cause right now my temps are 37 with my 2.8c running at 3.4 I have a gig of Geil ddr500 im running my setup at 1:1 and my vcore right now is set to 1.55 i tried raising the vcore to 1.6 to up my clock to 250 but then my comp wont boot. any suggestions on settings for agp core dram core vcore etc would be a great help. i know ican hit 3.6 with this processor
Important is that you lock your AGP/PCI. Does it not run at the same speed at same speed at 1.6v? BTW way is it a M0 stepping? D1's are usually not good overclockers. You should be able to go up to 1.65 if your temps stay around 50's under load. I wouldn't go higher than that unless you are using something other than air for cooling.
its a 30 cap M0 on an IC7 max II mobo. and where do i lock my agp. also after about an hour i noticed issues with my sound. im using onboard and guessing the overclock is messing with it cause its cutting out now. and im using watercooling that i put together myself. polarflo TT block and swift nb block with a BIX dual 120 rad
my main rig has the same cpu, mobo and ram at 1:1.
anything higher than 240fsb i need 1.62 vcore with everything on default.
anything higher than 250fsb i need 2.8v on vddr.
make sure your agp/pci is "fixed" in softmenu bios.
your temps are about right especially with watercool.
im gonna try and re mount my cpu block cause i dont think its working right. my temps seem to fluctuate alot. they will stay at 35-36 then jump to 42 and its not even under full load. thanks for your help so far.
