- Feb 25, 2008
- 20
- 0
- 0
So i finally bought a 5.1 setup for my computer and i opted to go for the Logitech Z-5500's. Along with these, i have an HT Omega Striker 7.1 soundcard and Windows Vista Home Premium.
I got the speakers all setup, turned on my computer and went away at configuring them. I was using the optical cable to stream DTS sound to the Z-5500's, but then i started reading up.
I was told (by various other forums) that for movies, the optical cord along with DTS or DDL is the best choice for sound......but for gaming (which is all my computer is meant for), using a 6ch direct setup is much better, and is the only way to get TRUE 5.1 sound in games.
Is that true?
Well, i decided to switch my hookup to the 6ch direct cable and started to reconfigure...
When i go into windows sound and configure my speakers, i notice that under "5.1 Surround Sound", it only lets you have side speakers hooked up, no rears. To use rear speakers in Vista, i have to set it at "7.1 Surround Sound" and deselect the side speakers options.
The problem with this is that whenever i do surround sound tests or music, Vista still thinks its a 7.1 setup and because of the lack of side speakers, it plays extra sounds out of the center speaker.
So i switched it back to "5.1 Surround Sound" and plugged the "rear speakers" cord from the Z-5500's into the "side speakers" output on my Striker 7.1. This is the only way i can use the "5.1" surround sound option in Vista....but its not how my speakers are setup.
What i need help with is how should my speakers be setup?
I know that with the 6ch direct cable, the front, rear and center/sub jacks should all be plugged into their respective inputs/outputs, but when i try to use my speakers in this way, Vista wont accept it and will only play 5.1 sound if i plug my rear speakers into my side speaker outlet on the Striker 7.1.
What am i doing wrong?
How can i get my setup to work just like a home theater........fonts are front, center is center, sub is sub and rears are rear (not sides)?
Also, how come in some games and movie clips/music, i get sound out of everything accept the center speaker (even the rears play sound)?
The mode on my Z-5500 is always on 6ch Direct Input (not PLII or 2x stereo).
Thanks for the help.....ive never been this confused with computer audio before.
I just need an idiots guide on getting everything to work the way it should with these speakers and vista.
Please.
Is that true?
Please.
