Need help with my overclocking project celeron tulatin!!!!!
Visa2
15
I bought intel celeron tulatin 1.0A, so I heard that its very overclockable because 0.13 micron. I saw at IXBT labs an article about overclocking celeron 1.0A@ 1.5ghz using Tt volcano 7 heatsink with pc-150 cas2 ram. So tried to push my Cpu to 1.5ghz but while rebooting my pc freezes, I also push it the voltage to the max 1.675v. I bought Tt volcano7+ to help with the temperature. the (volcano 7+ 38C) and the (retail fan 40C) I didn?t get it. So I decided to make a test using the air-conditioner to cool my case . It was incredible!!My board temp was 35 before but with air it was 17C Wow! and my Cpu 20C amazing. I oc 1.0a at 1.4ghz , 140*10 = 1400mhz using 1.500v and it work super stable. I push it at 1500mhz using any voltage, but when I reboot, it worked , but after it starts to reboot again. I think it my case temperature that didn?t give my cpu a chance to get more then 1333mhz. It could also be my power suppler(250W) that wont let my celery go to 1.5ghz . But I think It?s the ram I use pc-133 cas3, if I had pc-150 I think that I be able to reach 1.5ghz. My Project is to buy a small freezer to cool my pc from ?10 to 15C somethink like that? Or I?ll buy 6 powerful 80mm fans and place them into my case with some modification to the case using a drill, you know what I mean . I?m so confuse if you guys have
any tips or advice I could use it now????????
Intel celeron (tulatin) 1.0A 256k @ 1.33Ghz
Abit St6-raid
PC-133 CL3 256MB
Asus 7700 Geforce 2 GTS 32DDR @ (230/390)
Maxtor 15.gb 5400RPM
Soundblater Live value!
Power suppler 250W
