How to replace power-on passwords with your fingerprint
1. In the Fingerprint section of the Fingerprint software Control Center, complete the Enable Power on Security section.
2. Shutdown the system. On the first reboot you will be asked for your password and fingerprints. The second time you reboot it will only require your fingerprint.
Note: If you have enrolled more than one finger, the first time you use that finger to replace the Power on Password Security you will also be asked for your password.
Originally posted by: Slicedbread
From ibm.com
Originally posted by: JknowWhat
Not to be morbid or anything but I'm wondering what you would do if your fingerprint was no longer readable (ie. cut, burned off, lost the finger). Would you still be able to just use the PW?
