I finally have the money, and I'm getting a new CPU among other things, and need some help. I'm currently running on an Epox 6VBA2 (Apollo Pro 133A) with a Celeron 466, GTS 32MB, IBM HD, Diamond MX300. A couple high quality 128MB PC133 sticks are being purchased, but I don't want to spend $180+ just for 128MB, so CAS2 isn't real important to me, and I'm surely not going past 133MHz
. I picked up an Alpha PEP66 and some extra case cooling items a while back, and tried to overclock this CPU just for the fun of it. I didn't get it very far, but this slot1 coverter card doesn't have voltage adjustments. Anyway, I'm picking up a new CPU and would like to hit 1GHz with it.
it's just such a magical number, but I'll still be happy with a little less. Now, here's the questions:
1. What CPU would be the easiest to hit 1GHz with, without water cooling or a peltier? P3 800MHz or below.
2. Any extra cooling accessories you think I need?
3. Which is better, the IWILL slocket or the Abit? How does the FSB setting on the card affect the actual CPU speed?
4. What is the advantage of burning in the CPU, and what is the best method?
5. Anyone know how to make/buy a cheap temperature probe? The CPU sensor on this motherboard doesn't do too much good being attached to the motherboard.
6. On the Alpha PEP66, does it cool better with the fan pulling or blowing?
Thanks a lot, I'll post more questions if I think of any.
