Thanks in advance. I really have no clue about what I need.
1. What YOUR PC will be used for- I will be using my pc for MMO gaming and school.
2. What YOUR budget is- I don't want to spend more than 1,000.00
3. What country YOU will be buying YOUR parts from- USA
4. IF YOU have a brand preference- no brand preference
5. If YOU intend on using any of YOUR current parts- I have no parts
6. IF YOU plan on overclocking or run the system at default speeds- not sure on this probably default
7. What resolution, not monitor size, will you be using?- 1920 x 1080
8. WHEN do you plan to build it?- 1 week
9. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?- I need windows 7
