Question need help with my first build ! 1440p !
ainz own gool
i7 12700k
rtx 4070 super
ddr5 asrock z690 taichi
ddr5 ram 32 gb 5200mhz or 6000mhz
cooler freezer 240l or 360l
ssd samsung 2tb nvme
psu cooler master 850w 80+gold
boitier 4/5 fan
monitor 1440p !!!! under 300$
so is this build is good no need to add or remove something i did some research all seems fine no bottleneck no motherboard issue any suggestion !!!
BoomerD
66,364
14,770
Put your build into pcpartspicker. I’m not familiar with the fans you listed. Arctic Cooling fans are good…and inexpensive. (Not sure where you’re located)
FWIW, your basic build is pretty similar to mine…I game on a 32” Dell 1440 monitor with no issues.
Reactions: ainz own gool
