- Dec 1, 2003
- 880
- 1
- 81
I live in an apartment where I get residential electricity rates ($0.27kWh.) I know that may people will argue against mining Litecoin and Dogecoin because it will take me at least 3 years to get a return on my investment at current coin prices and difficulty. This is true and I may never even get a return at current prices. The reason I’m going to take the risk is because I believe that the prices will go up to at least what they were before and probably will go even higher. If not then I will be in debt and stuck with an awesome gaming system.
I cannot have a computer with 4 GPU fans blowing at max while I’m sleeping. In fact I can’t stand any noise which is why water cooling my only option. I need some advice and input on the system I put together. Consider the following:
I have chosen the following hardware:
[size=+2]
Case:
PSUs:
Motherboard/CPU/RAM:
GPUs:
[size=+2]
Cooling Fans:
Radiators:
CPU Water Block:
Pump:
Reservoir:
These are my concerns:
Thanks for all your help!
- It must be as quiet as possible.
- My breakers are rated at 20A but I doubt my wiring is rated at 20A
- I do not care about all the fancy glowing fans, shiny tubing and green colored coolant. I want the water cooling system to be entirely inside my case where it is unseen and unheard. My case will not have a window.
- I do not plan to overclock my CPU but I might as well add a water block to it. I do not care about getting my components to the lowest possible temperature. It does not matter to me if my GPU runs at 25C under max load or 40C as long as it runs stable and my system is quiet.
- Reliability is very important to me. This will also be my primary desktop computer where I will go on Facebook and may stop mining for a bit to play Crysis 3. I want an Intel system because in my opinion AMD is budget hardware.
- I plan to upgrade the GPUs when more efficient and faster ones are available.
[size=+2]
The System:
[/size]Case:
Fractal Design Define XL R2 – I currently own the original Define XL and it is awesome. It is built like a tank, has sound insulation padding and a ton of space. The R2 has 9 expansion slots for my 4 GPUs and allows me to mount radiators inside on the front and top
PSUs:
2X Antec HCP-850 – Why two? These have a nice feature where you can hook up both PSUs together and one will power on the other. I don’t need a total of 1700W but if I spread the load and put two GPUs on their own PSU the PSU fans will spin quieter due to lower load. The other advantage is that I have some headroom for future upgrades. Normally I would go with SeaSonic but from what I head the antec PSUs are the quietest in their power class
ASUS Z87-WS – I will have 8GB of ram and a 65W Core i5 that I do not plan on overclocking. I chose this motherboard because it has a hardware RAID controller, is made by Asus (I am a fanboy), is known to run well in 4-way CrossFire, and has a ton of features. Not sure if it’s really “server-class” but Asus has never let me down.
GPUs:
3X VisionTek CryoVenom R9 290 – These come with water blocks and should overclock very well. I’ll get 3 at first to measure the power consumption under full load and maybe then I’ll pop in a 4th one. I should be able to get 900kHs off of each one when overclocked.
[size=+2]
The Cooling:
[/size]Cooling Fans:
4X Prolimatech PRO-USV14 140mm – I heard that these are optimal for cooling radiators and are quieter than the more expensive Silent Typhoons. They are also PWM fans but I probably won’t need this feature and will hook them up to the Fractal’s built in fan controller.
Radiators:
2X Swiftech MCRx40 – These are 140mm radiators that I will mount to the front and top of the case
CPU Water Block:
EK-Supreme LTX CSQ – Simple water block to keep my CPU cool even though I’m not overclocking. Will keep things quiet.
Pump:
Swiftech MCP655 – I heard that this is the quietest pump out there. I do not need PWM control because the GPU’s will always be running. My goal is to set it at the lowest possible speed that will keep my system cool under full load.
Reservoir:
Bitspower Water Tank Z-Multi 250 Inline – I’m not sure what difference a reservoir makes or what inline means. Is it possible to mount this vertically?
- Will this setup be sufficient to cool my system with the pump running on the lowest and quietest speed? Again, I need this thing to be as quiet as possible. Can anyone recommend a quieter pump?
- I know the rule of thumb is that you use one cooling space (space for 140MM fan) on a radiator for each device. I will have 4 GPU’s and a CPU. Is it pushing it if I throw a 65W Core i5 into the 4 cooling space system?
- What effect does reservoir size have on the cooling system? Is the one I picked out unnecessarily big?
- I heard that it does not matter how well the water blocks work since they all remove so much heat that the overclocking capability will be limited by the amount of voltage the device you are overclocking can handle. Is that true?
- How does radiator size affect the system? I heard that the depth of a radiator makes very little difference and the thinner they are the quieter they are.
- This system will run on the lowest fan and pump speed. Will this be enough to keep it cool?
- Do I need a particle filter in line with the system or should I just put mesh into the resivour and clean it out eventually if there are any particles.
- Is water the best coolant to use?
- What fittings and tubing should I use? Again, aesthetics don’t matter I just need them to be reliable.
- Is there some kind of sensor I can install that will shut down my system if it starts overheating if the pump fails?
- Am I missing anything?
