- Nov 28, 2004
- 7
- 0
- 0
I'm putting a computer together and haven't done it in a long time. So I'm here to ask for your recommendations. Thanks for any help that you can give me.
In terms of CPU, I'm thinking of buying the AMD 64 3400 or the 3200. The price difference between the two are about $100. Is that extra speed worth $100? I also saw there are two different types of the AMD64. There is the Socket939 and the 1600. Is there a difference? Does it matter and if so which is better? Also, do I need to buy a heatsink for the cpu? Can u recommend a heatsink?
Now for the motherboard. Can you guys recommend one for me base on the AMD64 cpu.
Addtional criterias:
-S ATA capalbe since i have a sata hd
-EIDE capable , i have a dvd rw that's eide
-pci express (optional)
-supports ddr2 dual channel 533mhz (optional)
-LAN/sound already on mobo
Thanks guys. I hope that's not too much to ask for.
