Need Help with Memory for GB?
Jojo1971
2,200
Ive had my IT7-MAX2 v2 for a month now (1.8 @ 2.7 rock stable ) and I guess it's time to move to GB...Here's my problem...I have a Corsair 3500 cas2 512 mb and a Mushkin 2100 cas2.5 512 mb... Can I mix these two in a GB mobo or do I really have to buy another XMS 3500??? Pls reply and help me so I can order my GB ($229) and XMs (if needed) asap...
Thanks..
Abit IT7- max v2
P4 1.8 @ 2.7 @ 2.65v
Sapphire Radeon 9700
Sony 19" 400PS
SB Audigy + Pioneer VSX-505s + Bose AM5
16X Lite-On DVD-ROM
48X Lite-On CD- Burner
Leadtek Winfast 2000 TV-Tuner
ROMTEC HDD selector
40 GB Seagate + WinXP Pro ( for Gaming Only)
120 GB WD "J" + WinXP Pro (for other applications)
(2) x 100GB WD in RAID - 0 for storage
CHIEFTEC server tower
"I want the Sony Multiformat Burner next!"
BigJ
21,330
should be able to keep them as long as they can run synchronously together (same timings, speed, etc).
ArborBarber
320
I'm not sure...but...I don't think you can run them together. You need to run the same ram together, you can't mix different timed ram on a GB mobo...:(
