Need help with Magic ISO.
bchivers
188
I have a game as an .iso file and would like to be able to install it but I can't figure out how to use Magic ISO.
MustISO
12
Have you considered burning it to a CD (or DVD)?
Magic ISO can extract the image which may or may not allow you to install from the HD.
You can also use Daemon Tools to mount the image and run it that way.
bchivers
188
What I have is the game on a DVD as an .iso file. If I burn it to a DVD will it be playable from the DVD or will I be able to install it from there?
Thanks for your help.
