Need help with loose HDD sata connectors
Discussion in 'Computer Help' started by goodfella44, Nov 7, 2012.
  1. goodfella44
    goodfella44 Junior Member
    Jun 27, 2012
    14
    So I have recently upgraded my 5 month old Sony Vaio's SVT1311 hard drive, and I must have pulled the old one out wrong and loosened some connections. Every now and then I get a popup that my HDD is not connected. I made sure that is indeed connected properly, but I guess my question is how can I upgrade or replace these connections? Are there more secure type connectors I can use?
  2. Loading...
    Similar Threads - loose sata connectors Forum Date
    SATA ports are not SATA III Computer Help May 7, 2017
    Loose LGA 1366 Socket Computer Help Nov 6, 2016
    HD Audio Connector... loose... ok? Computer Help Jan 14, 2015
    Loosing Drives Computer Help Feb 3, 2009
    monitor loosing input signal after 20+ sec Computer Help Jan 4, 2008
  3. C1
    C1 Platinum Member
    Feb 21, 2008
    2,047
    22
    You should determine what is wrong with the connector. It could be simply deformed, but it might actually be broken resulting in an intermittent connection. A possibility is to try to shim the HDD with a thin piece of cardboard to put pressure on the connector with hope to achieve better/consistent contact. Otherwise, you'll need a computer repair shop to order and install a replacement for the damaged part.
