need help with linksys WRT54G
Originally posted by: Gillbot
hooked up directly to your PC via cable?
Try the linksys utility and reflash it.
it is connected directly to the PC via network cat5 cable.
i've looked on linksys website but couldnt find the flash utility. could you plz give me a link to the utility.
thanks
I don't ever recall a Linksys flash utility. I know routers like Asus have one but don't recall one on any of my Linksys routers.
You can try to TFTP a firmware to the router...I found the directions (again) with a Yahoo search. Download the latest firmware for you router and do the following:
spend few hours yesterady to unbrick the router, 54g v1.0,
steps to follow :
Static ip (of network card in PC) adress 192.168.1.105 is a good choice
Set Network card 10MB /halfduplex
plug the RJ45 PC-Router
*under windows XP run cmd and \ping -t 192.168.1.1
*under windows XP run a 2nd cmd (new window seperate from the ping window above) and get the following cmd line ready :
tfpt -i 192.168.1.1 PUT XXXX.bin (XXXX whatever the firmare name is) USE linksys firm 2.xx NOT 3.xxx (too big)
Switch on the router and check the ping : you should get 4 or 5 response at the very begining.
here is the trick : switch off / switch on / as soon as you see the ping starting RUN the TPFT command (timming is crucial)
Wait/Switch OFF/ Switch ON / check Ping (if you get continuous answer you are done... login in via web interface and update to the latest firmware you want.
if not start again.
Don't have a clue about current Linksys firmwares or their sizes (i.e. version 2.xxx vs 3.xxx) but apparantely TFTP has a size limit of 3MB.
Good luck.
Yes, this linksys utility will force a flash. I've used to to unbrick a few routers.
Ah, I see. Thanks. Didn't realize that Linksys had a "nice" TFTP utility! 😀
:thumbsup:
now after doing hard reset on it, i think it's dead now (the power led keeps on blinking indefinitely).
when i try the ultility, after 3 tries it says server is not respoding.
worse case scenario, get a ttl level converter for serial port, crack the cover, and try and get a terminal.
If that doesn't work, then you're pretty well hooped, unless you know someone at linksys 😉
Or program it via a jtag device! 😉
Did you follow the instructions on linksys's site?
There's a particular procedure to follow.
