need help with k7t pro2a
NforSa
make sure you have drives that support ATA66, make sure 'UDMA mode' is enabled in 'Integrated Perihials(sp)' in bios, and make sure ur using the proper ATA66 cable that came with the mobo :)
darkclouds
333
my drives do support udma 66 and bios is enabled. I'm also using the included cable. Still running at 33. Any other advise?
John
Moderator Emeritus<br>Elite Member
Use the 80pin cable and connect the BLUE end to the motherboard.
darkclouds
333
Thanks everyone. And John, you were right, i guess I had the cable on backward... didn't think it would make a diference.
Thanks again.
Regalk
1,137
Darkclouds - you broke the first law of installation. Go spank yourself silly before u caome back here.
