Need help with Java
Doodoo
1,423
K..i have a file and read all the words into array using stringtokenizer. How do I sort the array of words alphabetically? Thanks
GL
Search the net for a "bubble sort" algorithm and implement that in java. It's really easy...I don't have time to write out the code but it's best anyways if you understand these sort of things by learning them yourself.
Of course, it won't be as easy as just calling a function sort();)
-GL
Doodoo
1,423
Hehe...i was just lookin at the bubble sort...i tried it...but when it goes to compare the two array values...it says I can't use ">" with Strings....thanks for the help.
Edit: got it!!! had to use the compareTo function along with the bubblesort...now to doing a binary search on it.... Thanks for the help
ASK THE COMMUNITY
