Need help with JAVA
I'm confused... have you tried compiling this?
I get several compile-time errors ("incomparable types: int[] and int", etc.), mainly in LetterInventory.java.
Put this code in a file called Hello.java
run:
javac Hello.java
then
Java Hello
and tell us what output you get. This will confirm if your jdk installation is okay
If you are not already following a similar process with your own code, as I suspect you are not because it doesn't compile have a look at the Java tutorials.
