need help with java homework
alfa147x
im trying to compile this script:
import java.util.Random;
public class BankAccount
private double balance;
//Make tank
public tank();
balance = 0;
//consturct
//deposite
public void deposit(double amount)
double newBalance = balance + amount;
balance = newBalance;
//Take out
public void withdraw(double amount)
double newBalance = balance - amount;
//Get balance
public double getBalance()
return balance;
I get this error:
BankAccount.java:14: invalid method declaration; return type required
public tank();
1 error
Press any key to continue . . .
Your tank() method requires a return type. It looks like you don't intend on returning anything when the method finishes, so it should look like this (you're forgetting the void keyword):
public void tank() {
balance = 0;
Originally posted by: alfa147x
public tank();
balance = 0;
I get this error:
public tank();
Well, read the message... it's complaining because you're defining a method tank() but not saying what that method returns. i.e. Is it supposed to return an integer? A boolean? Nothing at all?
If the idea of "a function returning a value" is not something you're familiar with, then say so and I'll be more explicit.
Also, in your deposit() and withdraw() methods, you don't need to declare a new double variable and then make your balance variable equal to that. I mean it works but it's unnecessary. 🙂
