Need help with *.iso
darkclouds
333
how do I go about running a program with this extension? Please help. Is it an archive?
Thanks
thebigbossman
114
install the program it will detect the iso or use someother program to open the .ISO then burn it you have to hold shift the right click somethimes
PhaZe
2,880
iso is an image file
an image file one file that contains usually the content of a CD
you use IsoBuster from isobuster.com to see the contents of the image file
you can burn it using nero or adaptec..
