Need help with Installation Software (Ghost Recon) please help
Passa
46
I installed Ghost Recon about one month ago, but then I deleted it (not using the uninstall program)
So now when I go to install Ghost Recon it says its already installed, and it tries to Add/Remove itself, because it doesnt exist.
Is there any way I can re-install Ghost Recon again? I tried deleting the regedit key of Ghost Recon but it doesn't work still.
I can't install Ghost Recon :(
Any help appreciated
MacaroneePenguin
321
If you go to Add/Remove under Control Panel can you uninstall it that way?
If you go to the homesite of the game they might have a FAQ on manually removing the game... try checking that out
MacaroneePenguin
321
Yeah I know you manually deleted it but because you only manually deleted it, it still can be in the Add/Remove Programs List.
Passa
46
its still in the Add/Remove list, but it wont remove now :(
So when I go to install Ghost Recon it thinks the game is still installed and I cant isntall it :(
MacaroneePenguin
321
yeah, so therefore, there are still some registry entries in your system... you're gonna have to try to find them somehow.
There is a directory in the registry that lets you remove the programs on the Add/Remove Programs List...
I dont know remember what it was... sorry, you can try doing a search for it on the net
