Need help with Honeywell wifi thermostat install
SAWYER
16,742
42
I hooked it up but it didnt power on so I will try again. I snapped these two pics before I started so I could see where the wires originally went. I also will be using a Venstar Addawire to have the C wire that I will need
The second pic if of my old regular thermostat
stormkroe
1,550
97
Was your previous t stat powered without a battery? R and C should give you power, but if doesn't the 24v transformer in your furnace could be faulty (though the other functions probably wouldn't work).
gorcorps
aka Brandon
Jul 18, 2004
30,739
454
You already answered your own question I believe. You need to have the C wire to power it up, so if you don't have it hooked up you won't get power.
