Need help with homework - finding determinants
Yuriman
5,530
141
Problem:
Prove that (a-b)(b-c)(c-a) is the determinant of the matrix
|1 1 1 |
|a b c |
|a² b² c²|
I did matrices a few years back but have forgotten everything about them. I keep getting stuck. Please help!
Yuriman
5,530
141
Very helpful. I've read it, I'm making a mistake somewhere and it would be most helpful to me if I could see the problem worked in full so I can discover where my mistake is.
Yuriman
5,530
141
Makes sense. I was coming at it from a different (the wrong?) direction.
I was trying to simplify bc^2 - b^2c - ac^2 + a^2c +ab^2 - a^2b into the other expression and was failing miserably. Is it possible to do so?
Fayd
7,970
www.manwhoring.com
it's certainly possible, but more trouble than it's worth. all you have to do to satisfy the prompt is prove the values are equal. if they can be represented the same way, regardless of what way they're presented in the prompt, then they're equal.
Yuriman
5,530
141
Alright, how about this one:
|x 0 c|
|-1 x b|
|0 -1 a| = 0
Thanks so much!
esun
2,214
Your problem has nothing to do with determinants, it's just basic algebra. If you can apply the formula in the determinant article then you should brush up on your algebra to understand how to demonstrate the equality of your expression and the answer.
Dec 10, 2005
27,916
12,456
|1 1 1 |
|a b c |
|a² b² c²|
Code:
1*|b   c | - 1*|a  c | + 1*|a  b |
  |b2  c2|     |a2 c2|     |a2 b2|
Pick a row to work with, that becomes your coefficients (they go + - + -) and then the parts of the matrix that are not in the same column make up a new matrix to go with each coefficient.
Then reduce those determinants/matrices using ad - bc
eg: if the starting matrix was this
Code:
|a b|
|c d|
Yuriman
5,530
141
Simplifying I get ax²+bx+c=0, but I suppose I'm confused as to what it's asking for. The problem simply says "solve" and I simplify to the generalized form for a quadratic.
MovingTarget
9,002
115
What course/level is this for? I know its linear algebra, but is this a graduate or undergraduate level course?
Yuriman
5,530
141
Thanks. I finished up my math a while back but my wife is taking it right now and she asked me for help. It's good to not look like the idiot I am. ^^
