Need help with Graphics on COmp
kapao818
4
Yesterday when i started up my computer, all my colors were gone. I orginally had them set on "true colors" but when I started up my comp, I went to 16 colors! ANd for some reason i cannot go back into true colors. My video card is a: Standard PCI graphics Adapter VGA. (yes i know it's crappy but it's an old comp) I would try to find a new driver but I don't know where to get it. Can anyone help? Any help is much appreciated. Thanks a lot.
R2D2
280
You'll need to reinstall your video driver.
Check your motherboard's website for a driver download.
If no luck there, go to driverforum.com
Wolfsraider
8,305
if you list your motherboard and system specs we can try to help you better
the motherboard should have a sticker with the name and revision etc on it this will give us the info to help you find the drivers specific to your motherboard
another option is to list the computer ie compaq 9130 as this gives us a way to narrow down the choices since many here are well versed in old computers lol
last try this when armed with the numbers go to click here and type in the numbers and then "video drivers" or just "drivers"
hope this helps
mike
