Posted this at HardOCP so if you see it there, yes I am the same guy.
I just bought the Gigafast 8-port EZ800-S Switch.
I'm attempting to hook it up, but maybe I'm misunderstanding what it does. Here's my network:
The Gigafast switch receives my internet connection (port 1).
4 computers.
2 of them are connected to a router. The WAN of the router is connected to the Gigafast Switch. Both of these PCs are connected to the internet. No problem.
2 other PCs. I have them directly connected to the Gigafast Switch but they are not connecting to the internet. One of these PCs is XP, the other 98SE. Aren't these 2 PCs supposed to be able to connect directly with the switch for internet access?
Sorry if it seems a stupid question, but I don't know the complexities of networking. I just purchased this thing thinking it would work in the way I have described. I thought the clients could be direct connections to the PCs, or any routers (and like I said, the router works fine).
Help is appreciated. My router doesn't have enough ports to connect the other 2 PCs to the internet; otherwise, I would use it for that purpose.
4 computers.
