I recently purchased two 3COM 3C2000 NICs, and a Netgear GS108 switch.
I am not getting the speeds I was hoping for with the new hardware.
I am seeing 13 - 17 MBps with only these components connected. I have swapped cables to make sure I did not have one flaking out.
the 3COMs setup allows you to change the frame size, but it seems to not make much difference. It works at 9000, but no speed increase is noted. The default is 1500.
I also cannot locate any new drivers for the 3COM. The ones that came with it are from 2003.
Can anyone be of service? 🙂
Ron
Ron
