need help with ftp in SMC router
lordofdeath
367
hi everyone,
I need help with ftp on SMC router 7400BR.
i open port 21 for ftp but i can not ftp in from work. friend of my can login to my pc via ftp but I can not. as far as i read about SMC router, there is a P@ssive command mode that was implement into the router for security reason. is there anyway that I can over come this ? please help
ojai00
3,291
You might have to forward port 20 also as the service port. Just make sure that you are routing the ports to the computer that has the FTP server on it. Hope this helps.
lordofdeath
367
Hi,
thank you for reply. I want to know where in SMC router that I can do port forward ? is it under Virtual Server ?
Workin'
5,309
Originally posted by: lordofdeath
Hi,
Yes, under virtual server. Same place where you opened port 21.
lordofdeath
367
ok, i did open the port 22 in virtual server but i still can not get into my ftp server. it say 425 timeout something.
I run ftp server from freebsd. do i need to reboot my server or do i need to change anything ?
thank you all in advance
HDRick
59
You can just dmz the computer with the ftp server and you need to to set the ftp server to do passive If you don't want to do dmz you have to use something like flashfxp to get into the ftp server and tell it the ftp server using nat.
ojai00
3,291
You opened port 22 or port 20? :p
