Need help with front panel wiring on Tsunami case
desi01
I am trying to hook up the front panel usb and firewire on my tsunami dream case to my msi k8n neo2 mobo but all the labels don't match and the connectors don't seem to fit on the mobo. There are also different labels on the wires and in the mobo manual. Anybody have a diagram that could help me?
Bump. Please someone. I know a lot of you have this case. How did u hook up the front panel usb and firewire?
Do you have a manual for your motherboard? If so, then the diagram should be in there. If not, please list the labels on the wire and the labels on the motherboard so that we can tell you what matches up with what.
power goes on the power pins. HD LED goes on the HD LED pins. RESET goes on the RESET pins.... just look at the little lables and match them up.
If you make a mistake fix it. The computer won't' blow up or anything. It's trial and error without an ownersmanual. (The lable on the connector pins should face the "OUTSIDE" of the motherboard not inside
