Need help with finding a Firewire card for the DS3
Telon
63
Do to my HD video Camcorder I need to use Fire wire.
As most of you now the lacks any fire wire ports.
I looked around newegg and seemed that all the Fire wire cards had only USB ports for the inside. I would like to be able to use the front fire wire port on the P-180 case. If there is no way to do this then I will just do as I always had and run the cable to the back of a Fire wire card.
I just figured with as popular as The DS3 board and the P-180 was someone would have a solution.
AH forget what I asked please did some more looking and found what I needed
