Hello,
I have an Asus P8P67 Pro Rev 3.1 mobo, which has 4 fan headers, two are 4 pin (CPU and CHA1), and the other two are 3 pin (CHA2 and PWR). My case is an Antec Nine Hundred, which currently has 3 case fans, two in the front and one in the back (as factory installed).
My goal was to switch out the fans for PWM ones, and I got 3 Xigmatek XLF-F1255 for free after rebate, but now I'm stuck with how to configure them. I read all over the forums and found that in order to connect two fans to a header, I just need to make sure they won't overload that port. Now the fans are rated at 0.2A each, but the motherboard manual only specifies a maximum of 1A for the CPU fan, with no mention of power ratings of the remaining headers.
Should I get two 4 pin splitters, and run all 3 case fans off the single CHA_FAN1 header, hoping it can supply at least an Amp? Or should I put two on that header, and the remaining one splitting the CPU header with the CPU fan?
Semi side note, I've also gathered that when splitting two fans on a PWM header, the tach result will show the combined speed of both fans in the BIOS. Will this affect how they function ie. slowing both fans thinking they're running too fast? Or will they operate normally, just showing an erroneous RPM reading on the BIOS display?
I appreciate any assistance you can provide, thanks.
Edited to add links, now that I'm not posting from my phone.
