I would like to know if you guys think this would be a okay fan setup...
I currently have a MagiK fan that came with my Enlight 7237 for intake and a standard sunon for exhaust and the psu fan for exhaust(also using a MagiK fan). I recently decided to install grommets for the case, and noticed that my case is rather dusty with only two months of running 24/7. I assume it is because of the negative pressure in the case, and the fact that my intake fan doesnt have a filter. My intake doesn't have a filter because it uses the fan holder which came with my Enlight 7237 for a 80mm fan. I am now planning on changing the fans. Here are the fans that I have in mind.
Sanyo Denki(55.1cfm, 36dBa) - intake
Panaflo 80 L1A(24cfm, 21dBa) - exhaust
I have a question about the noise factor however. I will be installing a noiser fan for the intake than what I have currently. However I will be installing a much quieter fan for the exhaust than what I have right now(sunon 32dBa). Will the noise be lower than what it is now? Or will it be louder since the higher noise producer is closer to me. All this is when I am sitting down at my computer. (Tower is on top of the desk, right next to monitor)
- hito
- hito
