Need help with factoring.
UnoSigmaPi
919
Factoring has never been my strong suit. I was wondering if someone would be kind of enough to help me. Thanks in advance.
(y^3+27)
marcello
1,141
What chapter of Sigma Pi are you from? I'm from ZH at Santa Clara U.
I'll work on it for a bit and post back if no one has
marcello
1,141
Ok, this is what I got:
(y^3 +27)=(y+3)*(y^2-3y+9)
Don't know if that helps at all, but you can find all the roots now easily. Is that what you're trying to find?
D3m0nHunt3r
112
(y^3+27)
Well first you gotta slap some kevlar and metal plates on that Factoring suit of yours and then go into battle.
Syringer
19,333
Factor out y+3, then use either long or synthetic division to get the coefficients of its multiple..
That is, find out what (y^3+27)/(y+3) is.
kermalou
6,237
this post is worthless without pics
:camera:
(y^3+27)
first rule of factoring.. learn the formula's... there are only a few. Then apply the formula
(a+b)^2 = a^2 + 2ab + b^2
its associated one is : (a-b)^2 = a^2 - 2ab + b^2
(a^2 - b^2) = (a+b)(a-b) [a^2 + b^2 does not exist]
(a+b)^3 = a^3 + 3a^2b + 3ab^2 + b^3
(a-b)^3 = a^3 - 3a^2b + 3ab^2 - b^3 (check this one im kinda confused)
(a^3 + b^3) = (a+b) (a^2 - ab +b^2) (double check this one - I am sleepy but this is the one you need).
(a^3 - b^3) = (a-b) (a^2 + ab +b^2) (double check this one too - I am sleepy but this is the same formula as above for the negative.).
TuxDave
10,571
At some point.. you just realize that this is a sum of cubes and you can get the factorization via formula.
marcello
1,141
:camera:
Now that's funny, I don't care who you are, that's funny.
