Need help with Enlight 7237 case problem
geekender
I recently purchased a motherboard that has an onboard lan connector and my case does not have the blank that support this. Where can I get the blanks?
Thanks
Walt
I went there and only saw a # to taiwan. I checked out the messageboards and sent an email. No response from them. I was hoping to find another route. Dremel? Or can you purchase them?
The case backings I have all came packaged with the case. This one had knock-outs for everything except the LAN connector. I actually haven't seen many that come with the mainboard.
My ECS K7S5A (a board with lan and sound), came with its own backplate, just took out the one that came with case, pop'd in the ECS one and ta'da'. I would have thought it should have came with your MOBO, does it have a parts list in the MOBO manual?
Most mobos come with the backplate if the I/O panel is nonstandard.
For some reason, MSI isn't shipping their NForce board with one which is suck.
Hmmm, never ran into that kind of problem- get the closest match you can and get out the Dremel
