Need help with EE homework
JohnCU
Banned
x(t) = 7cos(100(pi)(t) - 3pi/4) + 5cos(100(pi)(t) + pi/2)
Find a complex-valued signal z(t) = Xe^(jw0t) such that x(t) = Re{z(t)}. Simplify z(t) as much as possible, so that you can identify its complex amplitude. Give the numerical values of X and w0.
So I did this...
z(t) = 7e^(-j(3pi/4)) + 5e^(j(pi/2))
7e^(-j(3pi/4)) = 7cos(-3pi/4) + j7sin(-3pi/4)
= -4.95 - j4.95
5e^(j(pi/2)) = 5cos(pi/2) + j5sin(pi/2)
= 0 + j5
-4.95 - j4.95 + j5 = -4.95 + j.05 right?
So z(t) = -4.95 + j.05
z(t) = 4.95e^(-j(pi/8))
Is that correct?
I read the question and I would solve it for you if I weren't so lazy. Unless you want to finish my Digital System Design lab for me 😛. If you want to know how to do it, just get rid of the 100Pi since they're irrelevant (multiples of 2Pi), then multiply and add. Unless you forgot a 'j' somewhere in your equation, both values are real so your angle is 0 and your magnitude is just adding the two numbers together.
