1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
ESXi 5 whitebox for learning, and watching movies/web browsing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$800-$1000
3. What country YOU will be buying YOUR parts from.
Canada.
Vendors most likely:
www.canadacomputers.com
www.newegg.ca
www.ncix.com
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I am pretty much set on the E3-1230 V2 CPU because I want to play with VT-d. I just need to make sure the motherboard supports it, in as small as a form factor as I can get away with.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No
7. IF YOU plan on overclocking or run the system at default speeds.
Stock or underclocking.
8. What resolution will you be using?
2560x1440 on a Dell U2711
9. WHEN do you plan to build it?
In the next two weeks.
$800-$1000
Canada.
www.newegg.ca
www.ncix.com
No
