Need help with dual monitors using ATI FireGL 8800 adapter
Stojakapimp
2,184
I just tried setting up a multiple monitor display at my work, and for the most part it is working fine, but I'm having trouble setting up the taskbar. Basically, right now the taskbar is extended across both screens, with "Start" in the bottom left of screen 1 and the system tray waaaaaay over in the bottom right of screen 2. I know it probably depends on the video card I have, but is there a way to make it so that the system tray shows up only on screen 1 (the primary monitor)?
I've looked in the Advanced setting under Display and haven't seen anything that would change the taskbar. It's really annoying, because I have to look waaaaaaay over to the other screen just to see the time or if I've received any emails.
Thanks!
Stojakapimp
2,184
Originally posted by: GrumpyMan
You can always use this Multimon.
It's free and works well.
I've installed it and tried running it, but it always says that "your system does not have multiple-monitor support" and won't load. I've searched online but haven't found any solutions except to reinstall it. I've tried that and it still doesn't work. Someone suggested changing permissions in the registry, but the program doesn't even show up in the registry. Not sure why it's telling me this, as obviously my system does support it since I'm using multiple monitors right now
