Need Help with downloaded game
Catchen22
I down loaded a game and it came in two seperate .ISO files. Did I down load some bogus files or is there some way I can use these files to play the game?
Catchen22
I don't think it is warez. One of the files took an entire 700 MB disk and the other is too big for the CD. Even after I compressed the files it's still too big by 6 MB. Is there a program or a way I split the files in two?
YaKuZa
995
Originally posted by: grunjee
Uhhh... is it just me or does this sound like Warez?
yeah, i was wondering the same thing. most game demos dont require you to burn iso images to play them. :confused:
thEnEuRoMancER
1,415
If you used eDonkey to download your, ehm, demo, it probably screwed up the filesize. Search eDonkey forums to find a utility that will cut off the extra bits.
