Need help with Dos command to fix Win98
habba
My friends system is corrupted. I can't access the D drive to reinstall windows. I can almost get to safe mode but get
SHLWAPI.DLL is missing and registry is corrupted.
Can you provide me with the copy command so I can try copying the DLL file from A to the system dir.
thanks
habba8
two different ways of doing this:
when youre at the command prompt you can use copy of xcopy, for examples and a way to use it use the following:
>copy /?
or
>xcopy /?
This will give you the syntax you need.
now to answer your question.
> copy a:\file.dl c:\windows\ <enter>
dam(presto)
