Need help with DNS error in XP Pro.
ZoSo
I'm running XP Pro with ICS. How can I stop this error?
This is the only error in Event Viewer.
Event Type: Error
Event Source: ipnathlp
Event Category: None
Event ID: 31008
Date: 11/4/2001
Time: 2:27:06 AM
User: N/A
Computer: MAIN
Description:
The DNS proxy agent was unable to read the local list of name-resolution servers from the registry. The data is the error code.
Data:
0000: 6f 00 00 00 o...
If you need any other info, just let me know.
Thanks,
I'm note quite sure how to fix it. Are you running ICS or something like that? Your best bet would probaby be to look up the error code in Microsofts Knowledge database.
I tried that all ready and it came up with nothing.
I think I got it though, I disabled "LMHOST lookup" on my NIC.
