Need help with DBAN
Josh7289
799
Okay. I want to completely wipe my HDD to do a clean reinstall of WinXP Home because my current install is kind of messed up after getting a virus, so I downloaded the .iso of DBAN and burned that to a CD. I shut down my PC, restarted it, plopped in the CD, and my PC booted from the CD. So I pressed F2 to learn more about DRAN, then I pressed Enter to continue. I was met with a screen for selecting what I wanted to wipe. I could choose either my hard drive or my only partition. I chose my hard drive assuming it would just wipe the partition the same.
However, the method I chose was DoD 5220-.22M (7 or 8 passes, not sure), not the default DoD Short (3 passes). Also, I told it to go through one round, as default. That sounds all good and well, but as of right now, it has been working for 3 and a half hours, but it's still writing pass 1 of 7, and the percent complete thing says only 00.85%. At this rate, it would take forever to finish, so I'm thinking this can't be set up right. Also, while my throughput started at something high, maybe around 40000 kB/s, it is now just above 1000 kB/s -- obviously not good. So, if something is wrong, how do I abort the wiping and try a different settinng without screwing things up?
My rig is in my sig.
Thanks.
http://dban.sourceforge.net/
MrChad
13,507
DBan is complete overkill for a simple reformat/reinstall. Just delete and recreate the partition in Windows setup.
Josh7289
799
What should I do right now, because I'm in the middle of the DBAN wipe? Should I just turn off the PC? And are you sure my HDD will be wiped of the virus remains if I simply do as you suggested? Thanks.
Kaido
Feb 14, 2004
51,777
7,330
Yup. When you boot into the Windows CD, delete the partition with Windows on it, then choose to format that blank partition as NTFS. It will completely overwrite everything on your hard drive. You will have zero viruses, just a nice, clean XP installation. Once you have XP installed, the first thing you should do is install a firewall like ZoneAlarm BEFORE you connect to the Internet. I repeat: do NOT connect to the Internet AT ALL without a firewall. I use the following software/schedule to keep my XP machines nice and clean:
Monday: Adaware
Tuesday: Spybot
Wednesday: AVG Anti-Virus
Thursday: Windows Update
Friday: Disk Cleanup, Disk Defragmenter
Adaware, Spybot, AVG, and ZoneAlarm are free; you can download them from Download.com. Windows Update, Disk Cleanup, and Disk Defragmenter are included with Windows. Also, use Firefox as your browser instead of Internet Explorer. Sticking to this routine - whether it's one scan/update a day or all of the programs at once one time per week - will keep your computer running smoothly.
Josh7289
799
Okay, so I turned off my PC during the DBAN wipe, and turned it back on booting from the WinXP Home CD. However, when it came up with the screen with partitions, all there was was the one unpartitioned space, a little smaller than my entire hard drive. Right now I'm trying to install Windows on this space, and I'll tell you what happens...But why wasn't there my old partition? After all, DBAN was only a little over 1% done with pass 1...
Baked
36,052
17
Originally posted by: Kaido
Monday: Adaware
Tuesday: Spybot
Do you go outta your house in a bubble?
MrChad
13,507
DBAN likely wiped out your partition table. No harm done; Windows will recreate it during install.
Nothinman
30,672
Because the partition table is the first 512bytes of the hard disk so it was the first to go.
Kaido
Feb 14, 2004
51,777
7,330
Monday: Adaware
Tuesday: Spybot
No, I switched to Mac :D
Josh7289
799
Cool. I'm running my new install of WinXP Home now, and it seems to be working pretty well. If I run into any problems, I'll create another thread. :D
