I recently built a system for a friend. I have built 15 other with no problems at all. Here are the specs:
IBM Deskstar 40 gig
Athlon 1ghz cpu
Epox 8KHA+ motherboard
256mb Crucial DDR
Windows ME was installed and after about a week or so the computer crashed. It had error and would not all a normal boot. Even in safe mode it would not work well enough to do a system restore. Windows 2000 was then installed. I downloaded some of the updates and everything seemed to be fine. It worked fine for me. Well two days went by before they decided to use it and now they get a check disk error. It says certain files on the hard drive are not readable. So basically it looks like I will have to do another install. What could cause this? I know they had downloaded a bunch of files off of Morpheus. Could they have gotten a virus that caused the system to crash and is maybe located in the MBR? Should I do a fdisk/mbr? I did not do that before. It just seems weird. I have never had something like this happen before. It look like a software error too with the messages that are coming up.
IBM Deskstar 40 gig
Athlon 1ghz cpu
256mb Crucial DDR
