Need help with cpu and memory settings
bigboxes
I am in the process of upgrading my beloved pc. I will be replacing the mb, cpu, ram, psu, and hsf. I am planning on staying with AMD, but I would value all opinions regardless of whether one has an AMD/Intel chip. I am leaning toward a KT333 mb, the XP2200+ cpu, and XMS(2700 or 3000) ram from Corsair.
I am curious about what is the optimal settings for the cpu and for the ram. I have never o/c my pc, but if I did, is there a limit (if you have stability) as to how high you should have your settings? I thought that the cpu fsb would be the limiting factor in bandwidth transfer, but I see many claims on AT about memory settings that are much higher than the cpu's fsb. Does this help with performance? Also, I have seen that there are settings in the bios for ratios between the FSB: AGP: PCI. What is the optimal for these and what will happen is you set this incorrectly? And lastly, is there any software that will help in deciding the optimal settings?
~box
Note: This is a repost from General Hardware. I was not getting any response. Thanks!
bigboxes, the answers to most of your questions vary from board to board, cpu to cpu, etc. If you could pick out some specific stuff and ask the same questions, we'll be glad to help. Look thru this forum to see what people are doing and buying. Good luck! 🙂
