- Jun 27, 2004
- 2,849
- 0
- 76
Water heater project: connecting a new cold water intake due to leaking 3/4 in valve.
So, I used the torch to remove the old valve. The pipe was cleaned, sanded, and fluxed. I heated the joint, applied the solder, and the first try was a really leaky seal. I heated the joint and removed the pipe - it was like the joint took up NO solder at all - no capillary action and the bead of solder was right at the joint. I recleaned and tried a few more times but the joint is not taking up ANY solder. I've checked a couple of videos, changed solder, kind of frustrated. Outside of calling a plumber, any advice?
