This is a gaming/heavy multitasking system. But I need to tone it down somewhat to keep it affordable. Please make some suggestions. I plan on safely overclocking after seeing what others are getting out of their systems, as more people get Conroe and new benchmarks arrive. I plan to order parts soon and I want to check to be sure that everything is compatible. Thanks. The part listed first is what I want and the things in brackets are questions/parts I may switch with to keep the price down. Sorry for the long post and so many questions, but I want to be able to be absolutely sure about everything before I start the build to be trouble-free later on.
CPU: Core 2 Duo E6700 Retail Box Processor [or should I downgrade to E6600? Also, where is a good place to buy Conroes (that aren't super price gouged) and when will they be in stock?]
Motherboard: ASUS P5W DH DELUXE, INTEL 975X LGA 775 CORE 2 DUO Mobo [When are the SLI motherboards coming out? Should I switch this motherboard or is it sufficient? It will not need to have a BIOS update, right?]
GPU: eVGA 01G-P2-N592-AX Geforce 7950GX2 1GB GDDR3 PCI Express x16 Dual GPU Video Card - Retail [Also, why is that there are so many 7950 GX2's manufactured by different companies? (You can see here.)]http://tinyurl.com/mhejl)[/L] What is the difference in them besides the price? Ranging from 499 to 599 with the 609 being the Xtreme.] [Is MSI RX1900XTX-VT2D512E Radeon X1900 XTX PCI Express 512MB DDR3 Video Card w/TV-Out, Dual DVI, & Video-In Retail ***Free Shipping*** from ZipZoomFly a comparable video card, since I would be saving close to 200 dollars with the rebate that comes with it? OR Should I get a mid-range card and wait to spend money on DX10?]
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory ? Retail [or perhaps OCZ Gold 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory ? Retail (slightly cheaper) which do you recommend? If I bought two of one of the above mentioned memories, would the 4 GB RAM be overkill?]
Monitor 19? Widescreen [Might upgrade later to take advantage of video card.]
Keyboard/Mouse: Logitech Cordless Internet Pro Desktop 967461-0403 Black 104 Normal Keys 8 Function Keys USB RF Wireless Slim Desktop Mouse Included ? OEM
HDD: Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive x2 [Will configure in RAID 0 probably.]
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive ? OEM [For OS and games.]
PSU: OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply 100 - 240V ? Retail
Case: NZXT LEXA-NP Black/ Silver Aluminum Construction Plastic Front Panel ATX Mid Tower Computer Case ? Retail
Headphones: Syba CL-ME-620 3.5mm Connector Supra-aural Stereo Headphone with Microphone - Retail
Speakers: Creative Inspire P7800 90 Watts 7.1 Speaker ? Retail
Other Drives: LiteOn LightScribe Dual Double Layer DVD Burner & SAMSUNG Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
OS: Windows XP Professional or perhaps 64 bit Professional [I might not get 64 bit pro because of all those driver issues I hear about.]
Also, if I dual boot with Linux, will the graphics card be recognized and will there be any trouble elsewhere? The onboard sound with the motherboard is pretty good, right? Also, I won't need any additional cables or anything for the hard drives and such, correct? (I heard round cables are much neater and easier to handle, can anyone recommend me some from newegg?) And finally one more thing, what's a good heatsink/fan for the processor for overclocking, better than the stock heatsink/fan?
Thank you very much and I appreciate your suggestions. (Please suggest anything that may help me!)
