OK, here is proof positive that a little knowledge is a dangerous thing. I have a watercooled tbird system and I wanted to protect it from meltdown when it is running all by its lonesome. I attempted to do this with two sensors and a circuit that would shut the machine down and keep it shut down until it is manually restarted. I built a water flow sensor from an old dc fan (details here) and another thermal sensor with a remote thermistor mounted on my waterblock. Both are wired so that they output approximately 5 volts when either the temperature gets too high or the water flow sensor detects no water flow.
I made a simple SCR circuit to shut my computer down and keep it shut down. It is powered off the 5v standby line and and the SCR drives a 5v relay that is normally closed and is in the power good line from the power supply. The 5v outputs from either the flow sensor or the temperature sensor are fed into the trigger of the SCR. A normally closed momentary switch is used to open the scr circuit when I want to reset the machine. When I first built it, I put a 30 mf electrolytic capacitor in the trigger line to smooth out any transients and prevent false latching. A picture of the SCR board (I don't have any means to do a schematic):
In spite of my ignorance, it actually worked when I first put it together. I was worried about using a 30 mf cap as a filter, but never got around to changing it out.
Now it does not work properly. Applying 5v volts to the trigger input will not latch the SCR. HOWEVER, if the thermal sensor is activated and outputs 5v and then goes inactive and the 5v goes low, the SCR will then trigger (i.e. low-high-low).
I replaced the 30 mf cap with an .1mf polyester film cap. That is in the picture and is now jumpered as it is either bad or is the wrong kind of cap. I also just added the diode to the trigger line.
I assume that the SCR has gone funky, but I really don't know. I also think using the 30 mf electrolytic cap was a bad choice.
I would appreciate any input anyone has and welcome any criticism (other than that I am a total dumb*ss). My electronics knowledge is limited to what I can pick up from rat shack pamphlets and simple circuits on the net.
I could also replace the scr circuit with 5v latching relay. I assume that if I use that properly (with a blockin diode) that would be a good choice. Is this correct?
Thanks for any help.
