Need help with C++ linked lists, returning a pointer
austin316
3,572
Ok, I need to know the code for a function that returns a head pointer. This program is done using template functions. So far, what I have is a struct for the node (includes data and a link), a class that has private member variables for the headptr, (which is what I want to return). I now need a non-member function that takes in two nodes and compares them. the only problem is I can't find how to make a function that will return the headptr node. any help will be greatly appreciated.
GigaCluster
1,762
This thread belongs in the Software Programming forum.
From what I understand, you want one of two things: return a node pointer OR compare two node pointers and return a boolean value TRUE or FALSE is they're the same.
Given that the node pointer is a custom type definition, like so:
typedef node* nodePtr;
TO RETURN A NODE POINTER:
nodePtr my_fun(nodePtr first) // parameters are optional; for example, to traverse a list, you need a pointer to the first link
nodePtr temp;
<traverse the list or whatnot>
return temp;
TO COMPARE TWO NODE POINTERS AND RETURN A BOOLEAN VALUE
bool my_fun(nodePtr x, nodePtr y)
if (x == y)
return 1; // they match
return 0; // they're different
Hope this helps.
worth
2,369
Why are you using a class together with a struct? What is the point? Try explaining your program better :p
austin316
3,572
thanks for the post, but I'm still confused. how do I make a typedef for a templated function? the name of my stuct is node, my template is template <class Item> and my class is name Bag.
i think it should be something like this, typedef node<Item>* nodeptr;
but that doesn't work.
austin316
3,572
my template is called class Item. didn't come out before. why I use both is because I feel its easier to use a struct instead of a class for nodes.
shikhan
834
<< thanks for the post, but I'm still confused. how do I make a typedef for a templated function? the name of my stuct is node, my template is template <CLASS Item>and my class is name Bag. i think it should be something like this, typedef node<ITEM>* nodeptr; but that doesn't work. >>
I agree with what someone said before... structs and a class? Uck...
I'm also not seeing why you need a typedef in here....
Give us what exactly your looking for in your program... If its a simple templated linked list and your looking to see how to make a perticular function, tell us what function and what your code looks like now. Then we can try to help :-D
PS. GigaCluster gave a general idea of what some function do although he left out a few things [ie, the nodes must be able to be compared and so have the assignment operator overloaded and such]
GigaCluster
1,762
<< shoot. shoulda went to class >>
Yes, that might've helped.
A linked list can be easily implemented with a single struct. No classes and no templates are required.
Example:
struct node; //declaring a node so that the typedef statement below wouldn't give a compile error
typedef node* nodePtr; //defining a new data type -- node pointer.
struct node {
int number; //actual data goes here
nodePtr next; //a pointer that uses our custom data type to point to the next link in the list
