1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming, probably starcraft 2, wanna play it at max settings at 1680x1050
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$800
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Prefer intel and nvidia
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
hard drive, monitor, keyboard, mouse, dvd-rom, OS
6. IF YOU have searched and/or read similar threads.
no
7. IF YOU plan on overclocking or run the system at default speeds.
stock speeds
8. WHEN do you plan to build it?
before the summer
thanks for any suggestions
$800
US
no
stock speeds
before the summer
