The best way for you to know my problem is to read here - http://boardsus.playstation.com/playsta...id=29454&view=by_date_ascending&page=1
the relevant messages are from PointGod and SmokeNMirrors.
I'll try to sum it up by pasting certain parts from there using the problem and suggestions from the other forum.
problem- "my problem is, this modem in basement, connected to my main router, ethernet to basement pc, ethernet to upstairs pc, now my ps3 is in a farther room upstairs and i have to unplug my upstairs pc's ethernet each time to use the ps3 online (with a coupler and ethernet cord) im wondering if i can put ANOTHER router upstairs so instead of the ethernet going to my upstairs pc, it goes to an upstairs router which then has a small ethernet to upstairs pc and another going to ps3"
suggestion - "Just add a switch upstairs (pull the cable from the PC there and plug it into the switch) then run ethernet to everythig upstairs.
If you want wireless upstairs you really need an access point as opposed to a router (the Linksys WRT54G's router can work this way). So:
-Your cable comes into your basement and goes to your current router (not wireless) and it's got a switch in the back and all the cabling and config on it stays the same
-Add a wireless router upstairs and plug that PC into it's switch.
-The cable that was in your upstairs PC should go to the wireless router upstairs, but instead of plugging it into the WAN/Internet port - plug it into a regular switch port (along with the PC), It's WAN/Internet port will be unused
You'll need some minor config on the wireless router so that it'll get along with your current router (do this 1st with just a PC and nothing else plugged in):
-Give it a LAN IP address 1 higher than your current router (so if your current router is 192.168.1.1 then assign the new one as 192.168.1.2)
-Disable the DHCP on it or it could conflict with the one on the downstairs router.
So your router downstairs will still be doing your network routing. The wireless router upstairs will be configured just as a wireless access point and just extend your network by adding more ports on it's switch as well as adding a wireless access. You could just buy a wireless access point (Linksys makes these too) but believe it or not, they actually cost MORE than a wireless router.
Hope this helps!"
I'm buying the linksys wrt54g router today.
extra question about the problem - "Alright, thanks for the quick reply, I'm probably going to get that soon then. You mentioned not plugging the thernet cable into its WAN port but plug it into its switch port... what would the switch port be? As for as i know from the current Linksys router I have, there is a port apart from the others that says WAN above it and I think its the same shape as the other ports and then the other ports are all beside each other... are you talking about one of those ones? If so, how does that work because you usually plug an ethernet cable in there if you want to connect something into the internet..."
reply - "All of the ports on the router are ethernet ports. The one that goes to the internet is the WAN port (wide area network). When I say "switch port" I mean one of the 4 others or LAN (local area network) ports. As you already have a router hooked up to the internet you'll be extending your network to the new router by plugging a cable from your 1st router's LAN switch ports to your new router's LAN swich ports. You dont' want the new router to perform routing (as it's already being done) and that's why it's WAN port will be left open. This is called "bridging" or "stacking" the switches on the same network and the new wireless router will be used in the role of a wireless access point."
So is that really all I have to do in order to get this to work?? and when he says this -
"You'll need some minor config on the wireless router so that it'll get along with your current router (do this 1st with just a PC and nothing else plugged in):
Disable the DHCP on it or it could conflict with the one on the downstairs router"
how EXACTLY do i do that? give me steps please
Hope this helps!"
