need help with boolean algebra and switching algebra please
MrDudeMan
15,069
94
yes, it is a homework problem. no, im not looking for straight answers. no, its not a grade and yes im actually trying my best.
with that aside, here is the problem.
i cant figure out what to do with 2 input voltages. we havent learned how to do it and im pulling my hair out trying to figure it out.
can someone please explain this to me?
problem
dighn
22,820
4
you don't have 2 + voltage sources. they are the same source connected together. just becuase they are seperated doesn't mean they are different sources. so you can draw a line connecting +v and +v if that makes it easier to see.
F = (Ab+Db)(BC + EF) -> invert signals because pmos is activated by 0
Fb = (Ab+Db)b + (BC+EF)b
=AD + (BC)b(EF)b = AD + (Bb+Cb)(Eb+Db)
if im right (not neceesarily) then you need to modify your ciruit slightly
btw Fb = Fbar = inverse of F
MrDudeMan
15,069
94
:eek:^100000
i cant believe i didnt think of that
you = the man
btw, i knew you would show up, but what took you so long? ;)
thanks a ton
edit: i think your equations are slightly off, but it got me going on the right track and for that i am very grateful
edit2: ignore edit 1. i am still teh noob.
