Need help with ASUS P4PE mobo
JaFF
Now Iv'e got my mobo running really well. My 2.4(B) cpu is running at 3033Mhz!
But I think the mem divider is like 1:1 I want it to be 4:5 but cant for the life of me find it anywhere in the BIOS setup.
I know a lot of people have this board already so I'd be hell grateful if someone could tell me how to set the divider to 4:5
Thanks
BDawg
11,631
There is no numeric divider. Instead, in the advanced properties, there is a memory speed choice which is the divider multiplied out into a MHz number.
At 133 FSB, I have the following speed choices
266
355
333
When you overclock the FSB, these choices change also. Yours will be higher. :)
JaFF
ahhhh great!!! thanks for that. my fsb is 167 atm. cant remember what Mhz I"m running, think its 333mhz so what divider is that i wonder
Viper96720
4,390
If your fsb is 167 you might want 1:1 divider if you run at 4:5 the memory will be at 417mhz. May not be able to run the memory that fast.
