I had to reset the Bios since I was getting No Post after changing the memory frequency.
Everything is working now, but when I start up the PC it shows the Main Processor
as AMD Athlon XP 1500+, even though I have a 2700 processor. Before I had to clear
the Bios, it read 2700. Are there some settings I should change?
In the bios some current settings are:
CPU External Frequency (MHz): 100MHz
CPU Frequency Multiple Setting: Auto
xCPU Frequency Multiple: 13.0x
System Performance: Optimal
xCPU Interface: Optimal
Memory Frequency: By SPD
Resulting Frequency: 166MHz
CPU Vcore Setting: Auto
If there are other important settings I should look at, let me know.
My Current Setup is:
1003 Bios
1.16 Nforce from Asus
AMD Athlon XP 2700
SLK-800 with Panaflow low flow
Artic Silver 3 Thermal Compound
Micron 512MB PC 2700 DDR (single stick)
Geforce 2 GTS 32MB
Soundblaster Live 5.1
40GB Maxtor 7200 Fluid Bearing
Antec Truepower 330W
Panaflow low flow case fan
Thanks
1003 Bios
AMD Athlon XP 2700
Geforce 2 GTS 32MB
Thanks
