Need help with an old ata100
Why would you want that old thing in a PC?
I suppose you could wire up your own, since that looks like a custom job specially made for them, no idea if they used a modified PATA cable or what they did.
Best case is, it is a normal PATA cable + power.
Worst case is, a custom PATA cable + power.
Um... no.
Ultra ATA still uses PATA cables, it just has 80 wire conductors and 40 pins.
My bet is this:
The signals assigned for 44-pin applications are described in table 16. Although there are 50 pins in the plug, the mating receptacle need contain only 44 pins (the removal of pins E and F provides room for the wall of the receptacle).
The first four pins of the connector plug located on the device are not to be connected to the host, as they are reserved for manufacturer's use. Pins E, F and 20 are keys, and are removed.
+-------------------------------------------1-E-----+
| o o o o o o o o o o o o o o o o o o o o o o K C A |
| o o o o o o o o o o o o K o o o o o o o o o K D B |
+44----------------------20-----------------2-F-----+
| Signal |Connector| |Connector| Signal |
| name | contact | Conductor | contact | name |
| Vendor specific| A | | B | Vendor specific |
| Vendor specific| C | | D | Vendor specific |
| (keypin) | E | | F | (keypin) |
| RESET- | 1 | 1 | 2 | 2 | Ground |
| DD7 | 3 | 3 | 4 | 4 | DD8 |
| DD6 | 5 | 5 | 6 | 6 | DD9 |
| DD5 | 7 | 7 | 8 | 8 | DD10 |
| DD4 | 9 | 9 | 10 | 10 | DD11 |
| DD3 | 11 | 11 | 12 | 12 | DD12 |
| DD2 | 13 | 13 | 14 | 14 | DD13 |
| DD1 | 15 | 15 | 16 | 16 | DD14 |
| DD0 | 17 | 17 | 18 | 18 | DD15 |
| Ground | 19 | 19 | 20 | 20 | (keypin) |
| DMARQ | 21 | 21 | 22 | 22 | Ground |
| DIOW- | 23 | 23 | 24 | 24 | Ground |
| DIOR- | 25 | 25 | 26 | 26 | Ground |
| IORDY | 27 | 27 | 28 | 28 | PSYNC:CSEL |
| DMACK- | 29 | 29 | 30 | 30 | Ground |
| INTRQ | 31 | 31 | 32 | 32 | IOCS16- |
| DA1 | 33 | 33 | 34 | 34 | PDIAG- |
| DAO | 35 | 35 | 36 | 36 | DA2 |
| CS0- | 37 | 37 | 38 | 38 | CS1- |
| DASP- | 39 | 39 | 40 | 40 | Ground |
|* +5v (Logic) | 41 | 41 | 42 | 42 | +5V (Motor) * |
|* Ground (Return)| 43 | 43 | 44 | 44 | TYPE- (0=ATA)* |
| * Pins which are additional to those of the 40-pin cable. |
Thanks for the help,
this drive is turning out to be more trouble then its worth. I will just hold onto it until i can salvage a pata cable.
That's "Laptop IDE". 44-pins. Can't say that I've ever seen a desktop cable adapter, but I have seen *external enclosures* for those, in fact, I may in fact still have one.
